1 - 13 of 13 Posts
Would my dodge dealer be able to convert my 07 Charger SXT to have a steering column shifter like that in the police package?
I've got a substantial amount of 2 way radio gear I want to mount inside my charger, and some of the police package mounting systems available would be PERFECT - but the damned center shifter gets in the way!
Thanks!
If they did it, wouldn't you lose the Auto-stick feature?
Nope the police chargers have auto stick on the column shifter . It should be do-able. The cop shifter is just bolted to the steering column . If you can order the part you may just have to bolt the shifter to your steering column if the bolt holes are there or you may have to change the entire column to the police unit .
The shifter in the charger police cars looks awkward. IMO, they ruin the interior look of the car.
sometimes function is more important than form and it wont look like a chopped up cheaply done mod if the factory parts are ordered
It actually comes out of the dash...
Yes it does but if you pulled back that cover on the dash you would see its bolted the the steering column .
You will also loose the ability to telescope the steering wheel. At least that's the reason I believe mine won't telescope, it only tilts.
1 - 13 of 13 Posts
