1 - 4 of 4 Posts
Hi All,
I have a 2010 Charger SXT. Since purchasing it, there have been numerous occasions (generally 1 - 3 times per month) where I'll turn on my car and the radio (I believe I have the pro pack with 30GB HDD, Serious XM, etc.) will stay black with the uconnect logo for about a minute, shut off, reboot, then start working. Sometimes it just shuts off and I have to press the power button to make it work. There seems to be no rhyme or reason to it.
Also, I had a compustar alarm installed (w/ Blade unit) and I've been having having a problem with the door locks. When I engage the alarm, the alarm always engages, but sometimes the doors do not lock. I must disarm and rearm the system for it to work. Also, sometimes they trunk does not open and I must unlock it twice. I have been to my alarm installer and they have replaced both the compustar alarm module and blade unit (which I believe talks to the vehicles data BUS) to no avail.
Has anybody had or heard of these issues before? I don't know if they are related but they seem to be (today the radio did not turn on and then I went to lock the vehicle & arm the alarm and the doors did not lock)
is it the "ADS-BLADE AL" the door lock and immobilizer bypass
or do you have relays for ur door locks
see if the compustar is programed right
on mine(DEI not compustar) i can change it so it takes to 2 pulses activate the lock/unlock
after programming mine i accidently left it in the programming mode and none of the buttons worked right
so that might be it( could be in programming mode)
*disclaimer i'm not a pro and have only done this once*
and with a can bus system u can easily screw things up with bad wiring
As far as I know, it's the ADS-BLADE AL. I know it's not in programming mode, I saw them finish the programming and the compustar was out of programing mode.
1 - 4 of 4 Posts
