Yeah! A reply from the Man itself!
Glad to see you join the thread.
I think we can all agree that your statement very well resume the overall situation.
But just to make it clear, when I talked about doing analysis, it wasn’t about breaking down the competitors’ products to explain the molecular level of things. It was more about helping the average Joes to make an informed choice by doing what you’ve already done elsewhere in the forums: take a competitor’s MSDS (I didn’t even know that acronym a few weeks ago :S) and explain what is hidden in there and why it is bad for cars (or good… it could happen I guess)
For most people, common MSDS are like trying to read a dead language and even among those who could usually find their way through it, most additive related MSDS hide useful information in such a cryptic way that only a few chosen can manage to find it.
Of course I suppose another interesting way to expose that information could be to do the exact opposite and make a post about each common bad ingredients, explain what it is and why it is bad as well as including a list of known offenders.
Again, finding a big chunk of useful information like this in a single thread will add visibility to your products, will help people to understand more what they put in their car and if done properly they won’t have the impression this is done to bash competitors and they will see that all the information that will be provided there can be verified.
While that might be interesting in some fashion, it is important to realize that everything....and I mean EVERYTHING out there in terms of fuel additives are single phase cocktails that incorporate the same things. It is like saying well, ABC cake mix has flour, sugar, eggs, and oil. DEF cake mix has flour, eggs, oil, and sugar. GHI has sugar then flour and then eggs but no oil. The thing to understand is that they are all varying degrees of the same ingredients. The point is that we don't want eggs mixed with our flour because neither eggs nor flour are good in our glass of chocolate milk! These off the shelf fuel products don't belong in our fuel!
104+ Octane Booster is a perfect example: $10.99 for up to 20 gallons of fuel. Our ACES IV at retail is $75.95 (Charger Forum people get it for $67.60 or $234.00 per gallon (or $58.50 per quart!!) It treats 192 gallons of fuel. Pretending that 104+ was the same....AND IT IS NOT......you would need 9.6 bottles to treat the same amount of fuel. So $10.99 x 9.6 = $105.51 x 1.0775 (tax) = $113.68 for 192 gallons of fuel. Compare that to ACES IV at $67.60. So 104+ is 59.2 cents per gallon where ours is 35.2 cents per gallon. Now the MSDS Sheet on this product tells it all too:
Proprietary additive - methyl cyclopentadienyl manganese tricarbonyl (CH3C5H4)Mn(CO)3 - Manganese....erodes cylinder walls....like jewler's rouge!!!
Petroleum Distillate - Dearomatized kerosine - 64742-47-8 KEROSINE!!!
Hydrotreated Petroleum Oil - 64742-52-5 hydrotreated heavy naphthenic - Napthalene is dry cleaning fluid but heavy type that produces gum and varnish in your cylinders and engine oils.
Don't use any of the additives off the shelf as they will all produce interactions, reactions, and ultimately be much more costly than using ACES IV which we designed to be just exactly what the fuels need....both gasoline and ACES II for diesel.
By the way, while you are here I would really appreciate, if you had to do it only once, if you could give your opinion (technical or at least personal) about products from Bell Performance. Among them, they got a product, Mix-I-Go, that while I do not think it is superior to ACES IV it does look very similar. Here, from the information I could gather: the product is mostly used at the industrial level (with some success it seems) and is kind of underground among the car enthusiasts, marketing material also put a similar emphasis about being different from the “thousands of all-the-same competitors”, base recipe has been kept secret and improved over the years to meet new requirements. Also various claims make it look like a very good ACES IV-like product (after all it’s their job to make people think it is
While I was looking for an additive to try, it has come as a close second to ACES IV. I guess I subconsciously hope that you tell me it’s a good thing that I didn’t go Bell’s way while including all the valid reasons a professional of the subject like you could provide.
I won’t mind if you don’t reply to this, but again it would be really appreciated.
Again, Mix-I-Go is for 2 stroke and 4 stroke use. The release rates alone in gasoline 4 strokes vs. 2 strokes is completely different. We have ACES IV for 4 stroke and ACES IV-2S for 2 stroke that are different formulas to deal with the oil mix and oil injection in the engines.
92% of the mixture is petroleum solvents or "stoddard solvent"
See Below:
SECTION I - Material Identity
Part Number/Trade Name MIX-I-GO
National Stock Number 681000N000798
CAGE Code OOO34
Part Number Indicator A
MSDS Number 182896
HAZ Code B
SECTION II - Manufacturer's Information
Manufacturer Name BELL LABORATORY INC
Emergency Phone 305-831-5021
MSDS Preparer's Information
Date MSDS Prepared/Revised 01JAN85
Date of Technical Review 09OCT81
Active Indicator N
Alternate Vendors
Vendor #5 CAGE BCGHY
SECTION III - Physical/Chemical Characteristics
NRC License Number NA
Net Propellant Weight (Ammo) NA
Appearance/Odor AMBER COLOR, FREE FROM SEDIMENT, LIGHT ODOR
Boiling Point 318-456F
Vapor Pressure 2
Vapor Density 4.9
Specific Gravity 0.7770
Evaporation Rate 0.1 (BU AC)
Percent Volatiles by Volume 100
Container Pressure Code 4
Temperature Code 8
Product State Code U
SECTION IV - Fire and Explosion Hazard Data
Flash Point Method UNK
Lower Explosion Limit 1.0
Upper Explosion Limit 6.0
Extinguishing Media FOAM, CO*2, DRY CHEMICAL, USE WATER AS COOLING AGENT
Special Fire Fighting Procedures SELF-CNT BRTHIN APPAR W/FULL FACE PIECE IN POS PRESS MODE
Unusual Fire/Explosion Hazards VAPORS ARE HEAVIER THAN AR, MAY MOVE ALONG THE GROUND. REMOVE IGNIT SOURCES. RESIDUE MAY ALSO IGNIT
SECTION V - Reactivity Data
Stability YES
Stability Conditions to Avoid AVOID HEAT, SPARKS, OPEN FLAME, FIRE
Materials to Avoid AVOID CONTACT WITH STRONG OXIDIZING AGENTS
Hazardous Decomposition Products CO & CO*2 POSS FROM THERMAL DECOMP
Hazardous Polymerization NO
SECTION VI - Health Hazard Data
Route of Entry: Skin N/P
Route of Entry: Ingestion N/P
Route of Entry: Inhalation N/P
Carcinogenity: NTP N/P
Carcinogenity: IARC N/P
Carcinogenity: OSHA N/P
Symptoms of Overexposure EYES: SEV IRRIT,RED,BLURR. SKIN:MOD IRRIT. INH
IZ,WEAK,NAUSEA,UNCON,ASPHYX.INGEST:GI IRRIT, VOMIT
Emergency/First Aid Procedures SKIN:WASH W/SOAP&WATER. REMOVE CONTAM CLTHNG, WASH BEFORE REUSE. EYES:FLUSH W/LG AMT OF WATER. GET MD ATTN. INH:REMOVE TO FRESH AIR. GIVE OXYGEN/RESTORE BRTH IF NEC. CALL MD. INGEST
OSS CHEM PNEUMONFROM ASPIR. DO NOT INDUCE VOMIT. CALL MD
SECTION VII - Precautions for Safe Handling and Use
Steps if Material Released/Spilled SM SPILL:ABSORB LIQ ON PAPER, VERMICULITE OR OTHER ABSORBENT & TRANSFER TO HOOD. LG SPILL:ELIM IGNIT SOURCES. PERSONS NOT WEARING PROTEQUIP SHOULD LEAVE AREA. STOP SPILL, DIKE AREA, PUMP LIQ TO SALVAGE TANK. ABSORB REMAIN MATRL, PUT IN CONTAINER
Waste Disposal Method MFR RECM:SM SPILL:ALLOW VOLATILE PORTION TO EVAP IN HOOD. ALLOW VAP TO CLEAR HOOD DUCT WORK. BURN REMAINDER IN IRON PAN. LG SPILL:INCINERATE LIQ. PUT ABSORBED MATRL IN LANDFILL. DISPOSE LAW FED, STATE & LOCAL CODES
Handling and Storage Precautions USE W/ADEQUATE VENTILATION. AVOID PROLONGED OR REPEATED PERSONAL CONTACT
Other Precautions CONTAINERS OF THIS PRODUCT MAY BE HAZARDOUS WHEN EMPTIED. SINCE EMPTIED CONTAINERS RETAIN PRODUCT RESIDUES (VAPOR, LIQUID AND/OR SOLID)ALL HAZARD PRECAUTIONS IN DATA SHEET MUST BE OBSERVED
SECTION VIII - Control Measures
Respiratory Protection NIOSH/MSHA APPRVD RESP PROTCTN,SELF-CONT IN POS PRESS MODE, IF NEC
Ventilation SUFFICIEMT MECH & LOCAL EXHST TO MAINTAIN EXPOS BELOW TLV
Protective Gloves NEOPRENE,BUNA-N
Eye Protection CHEM SPLASH GOGGLES
Other Protective Equipment TO PREVENT RPTD/PRLNG SIN CNTCT-IMPERVIOUS CLOTHES, BOOTS
Supplemental Health/Safety Data ADDRESS: 1340 BENNETT DR., LONGWOOD, FLORIDA32750
SECTION IX - Label Data
Protect Eye NO
Protect Skin NO
Protect Respiratory NO
Chronic Indicator UNKNOWN
Contact Code UNKNOWN
Fire Code UNKNOWN
Health Code UNKNOWN
React Code UNKNOWN
SECTION X - Transportation Data
Container Quantity 1
Unit of Measure QT
SECTION XI - Site Specific/Reporting Information
SECTION XII - Ingredients/Identity Information
Ingredient # 1
Ingredient Name
STODDARD SOLVENT CAS Number 8052413
NIOSH Number WJ8925000
Proprietary YES
Percent
92 OSHA PEL 500 PPM
ACGIH TLV 100 PPM; 9293
We don't really have to waste time looking at all the other products that are distillates, polymers, alcohols, acids, alkyli and metals. These are not good for any engine and shouldn't be used.
ACES IV is really.....REALLY all you need.
Regards,
Brian
BND Automotive LLC:driving:
440-821-9040
www.bndautomotive.com
