- 2013 Dodge Charger 3.6 engine. non flex fuel
- Faulty or worn spark plugs *----------------------------------------replaced
- Faulty spark plug wires or coils *----------------------------------replaced
- Faulty fuel injector----------------------------------------------------replaced
- Camshaft sensor defective-----------------------------------------replaced
- Crankshaft sensor defective-----------------------------------------replaced
- Engine timing off----------------------------------------------------------checked
- Leaking head gasket-------------------------------------------------did leak down test OK
- Low engine compression-------------------------------------------did compression test OK
- Poor quality fuel ------------------------------------------Ran several cans of fuel cleaner through it
- Vacuum leak-------------------------------------------------checked
- Low fuel pressure checked all of these----------------checked still miss fire on 1,5
- these are things I've already done , Don't know where to go from here.
