1 - 2 of 2 Posts
I cant seem to find answer. Code keeps coming up after clear. I had this code present on old motor .Just installed rebuilt motor and codes coming back. I am getting bank one and two . I replaced 02 sensors. Could problem causing this code of blown last motor and could it blow this one .please help
P2098 - DOWNSTREAM FUEL TRIM SYSTEM 2 LEAN
What year is the car and what engine is in it? Problem could be the O2 sensor. Best to use Mopar OEM O2 sensors since some aftermarket O2 sensors don't work well with the Dodge Charger PCM. Could also be an exhaust leak, wiring harness/connector or contaminated fuel.
1 - 2 of 2 Posts
