Actually it means that the 5V Output Reference Voltage 2.Hi charger threw a cel code this morning. Code is P1622. Googled and its a cylinder select problem. Sounds bad? Anyone else get this code before?
2014 phantom black rt max
It's not unusual for an O2 sensor going bad to throw intermittent codes like that. Our '05 Grand Caravan did that for several weeks before the CEL lit steadily.Hmm drove to work this morning then drove over to a restaurant for dinner tonight. Check engine light was gone when I started up the car to go home after dinner. I'll keep an eye on it. Seems weird that the code pulled up I didn't do anything different but fill up last night.
Hopefully everything is ok.
I suspect you have a sensor failing and it's just a matter of time before it's toast. No worries though, it won't cause any damage and once it's throwing a constant code, you can get it replaced.
There is a technical service bulletin 18-039-13 possibly related to your concern. Have your servicing dealer inspect and diagnose issue.Hi charger threw a cel code this morning. Code is P1622. Googled and its a cylinder select problem. Sounds bad? Anyone else get this code before?
Hey Gates did you ever resolve this issue? My '14 Ram has P1621 and P1622. Logging shows neither front O2's are responding. Thanks!Ok that is good to know its not a huge deal. Thanks!
Hey there. This issue eventually went away the next day on its own. I think the problem ended up being that the night before I filled up my tank very full and then topped it off with fuel additive. The code only came up once. After driving that day and using some fuel the code didn't come on again the next day and it hasn't popped up since. Now I only fill up till first click and then add my fuel additive. No issues with that.Hey Gates did you ever resolve this issue? My '14 Ram has P1621 and P1622. Logging shows neither front O2's are responding. Thanks!
Strangely enough my CEL went out 2 days later. Gremlins I tell ya.Hey there. This issue eventually went away the next day on its own. I think the problem ended up being that the night before I filled up my tank very full and then topped it off with fuel additive. The code only came up once. After driving that day and using some fuel the code didn't come on again the next day and it hasn't popped up since. Now I only fill up till first click and then add my fuel additive. No issues with that.
