Can any body explain to me what are cnc ported heads?? And should I get CNC heads??
They are cylinder heads ported to accompany air to flow more smoothly and at a greater volume into the cylinder, ported by a CNC machine. If you are gonna put those heads on there a lot and i mean a lot of parts that I would consider changing at the same time.
If you are gonna pull your cylinder heads might as well change the cam and lifters and cam... what’s the
Trim of the charger?
