Regarding my 2008 R/T R&T
Last night I was taking my GF home and had the dual climate set for 2 different temperatures (68 & 76) and the vent select set to auto.
1st, I noticed that her side was blowing through the floor vents and my side through the dash, I guess both sides operate independent of one another in both temp and vent select when set to auto?
2nd, while discovering the notation above with my hand under the dash i managed to burn the hell out of my finger, are the heater core pipes on the drivers side under the dash and are they normally insulated?
The vent selections can be different on each side when in automatic mode based on the difference in the temperature selected. Each side operates independently to adjust temperature and (when in auto) vent position also.
The heater core is indeed on the driver's side of the unit and probably what you burned you hand on...
