1 - 20 of 23 Posts
So I got caught up on a few mods today, mainly NOESP (woot! that's fun!) and a combination Auto Coolit and new Tstat. I used a Stant 170 degree, forgot to take a photo of the Tstat itself, but have one of the box:grin: . It is a 64mm diameter, but actually went in fairly easily, to my surprise. I did spend a lot of time reading Meisters goldmine of info on this topic.
Installation went well, but I wanted to share this with you (see pics). When I bought the new Tstat, I saw a sign in the store that said "replace your thermostat every 60,000 km (or 36,000 miles for our american friends). Mine just rolled over 59,000 km, so I thought to myself "My, that's very timely then!"
But I was still surprised to see the condition of the OEM Tstat when I removed it - it was in two pieces, and the rubber ring over the faceplate (not the sealing gasket) was shredded.
So indeed, seems like I caught his just in time, although I have to say the car seemed to be working normally. I've been monitoring the tempereature with EVIC for the last week so I could see the difference after installing the Coolit/new Tstat. Temps were hovering around 205-210 degrees before the mods. With the mods, and Coolit default settings, it is running between 176-185 degrees.
So, even if you do not want to use a different Tstat, check and replace yours anyway, especially if mileage is getting up there. It was a very simple job to replace mine, and I am no mechanic. Just followed the instructions posted here and on lxforums.com
Maybe poor quality product DC is using. Isn't stant also the stocker?
I had the same Problem on my 300. Dealer replaced it because car wasn't going past 1/4 on the temp gauge, they found the T-Stat in 2 pieces! Car had 30k miles.
It's actually an incriminate of measurement. Red being the most precise
Actually red is between Burnette and Blond.... slighty heavier than a Strawberry blonde, not quit as fine as a "true" blond......
If anyone's interested in a Coolit fan mod, I lowered the price for December.
The Auto version is now $99 shipped (was $150)
The Manual version, perfect for track use for Diablo users is now $59 (was $75)
I have both in stock.
secret link to lower prices: www.noesp.com/sale.html
I'm now near 73,000 km and today temps had a hard time going over 1/4 of gauge. I guess it's time for replacement.
At least now i know why it took so long to reach it's running temp.
That is crazy, seems pretty low in miles to see that kind of failure. I wonder if I will need to keep an eye on my Napa 180 t-stat
You should have popped a code and chime for this failure.
No code or chime just take a bunch of time reach temp. Trip to work is about 20 miles and when i got there tonight temp was at 176F, got to 206F on my way back to home.
I'll swap it for 180F
Normally, if the PCM doesn't see the engine temps reach operating parameters within a specific time, you get the "ding". Guess you are right on the edge of being OK.
Has anyone with a V6 had this issue with their thermostat? I have over 52k on my SXT. Should I look into this, too?
I installed a 4128 180 deg. t-stat about 5 months ago and it is now stuck open, gonna have to replace it this weekend. What a drag.:angry:
Shouldn't this kind of failure be corrected under warranty... Or do I smell a TSB perhaps???
I can't explain the separation of the T-Stat, but the shredding of the gasket probably happened when it was installed or removed.
I also wonder for those who had the coolant flush TSB (like me), if the dealer put in a new T-Stat then or just left the old one in the radiator housing??
1 - 20 of 23 Posts
