DAYTONA_R/T said:
as for the fuel maps... dont expect to get that on a programmer... a novice could seriously screw up the car... and hand held programmers like to keep adjustments minimal to keep idiots at bay....
once the code is cracked... expect to see something similer to LS1EDIT for these engines... which from your post is more what you are looking for
An ls1 Edit type would be great and dangerous as well. As far as fuel map. I am not thinking about creating fuel maps from scratch but a program that allows you to adjust the curve. Like a stereo equalizer. Or a program that copies the WOT map and will automatically create a new map to optimize performance based on collected data from several sample runs.
That may be a ways in the future.
I think most people like me would prefer not to run premium all the time. That is why Hypertech started their Duel Fuel programming. It doesn?t work as well on high compression motors but the 5.7 is relatively low compression.
It?s easy enough to load the premium program and fill up with the good stuff before going to the track. This will give you the extra ?% gain.
duel fuel
But then again I will take what I can get.
________
WEB SHOWS
