1 - 2 of 2 Posts
Hello everybody,
Recently I started to feel vibrations starting at 70 mph and up, after inspection it seems that driveshaft central bearings is reponsible (barely turning and shaing). Now is the worst part, it seems the only part that can be replaced is whole drive shaft... As I live in EU it is hard to get any used parts here, so maby you know if drive shafts from challengers are interchangable with chargers eg 52123975AG and 52123977AG?
Or is there any metod to replace central bearing (how to disassembly center joint and the reassembly it again)?
Thaks in advance for any hints in this subject.
Wysłane z mojego VOG-L29 przy użyciu Tapatalka
When I had problems with my 2014 the bearing wasn't listed for that year or newer from all suppliers but it was still the same bearing and setup as older years
But my problem was bad u-joint and had to replace the driveshaft anyway.
When you take the driveshaft out the middle slides apart. There are some YouTube videos about replacing the bearing.
1 - 2 of 2 Posts
