Does the predator actually change the gear ratios, or do you have to install the gears then tune the car with the predator?
Once you install new gears, I believe that you can then use the Predator to update the computer so it knows about the change.
Gear ratio is a mechanical thing. The Predator cannot magically change what size gears are in your rear end. You have to physically change the gears, then you can use the Predator to tell your car that you changed it.
