I was wondering if it was possible if I could put a 2011-2014 charger steering wheel, radio, and the speedometer into a 2006-2010 charger. Would it fit and how hard would it be wiring wise?
2012 SRT Charger, 2003 Ram hemi, 2005 Magnum
Could you bolt the wheel in? Most likely. Would the airbag wire in/work properly? Iffy at best. Everything else would most likely not function correctly unless you intend to swap in the ENTIRE electrical system from a donor car.
