I am not sure if I should have the coolant flushed. The car only has 16K miles but the car was built 4 years ago (driven for 3 years-sat at the dealership for 14 months) and not so sure if the coolant is really good for 5 years.
it depends. it needs to be tested but HOAT coolant has different methods of testing then other coolants.
Bnd has a thread about coolant in their section that has tons of info.
Honestly i wouldnt mess with it til 5/100 unless your gonna upgrade to his coolant, your probably fine. the key to coolant is to keep it full, clean and fill with distilled water/or filtered water, not tap water. that will help her out
I generally do it at 3-4 years since the cost is relatively low (a gallon of G-05 and a few gallons of distilled water from CVS @ about a buck each). Anything with Dexcool in it gets done every 2-3 years.
Best,
