I've done it several times in my driveway on ramps. (Magnaflow on my V6, flowmasters on the V8, Borla, and finally the Magnaflow on the V8)
It's easier with a lift. removal of the old pipes, from the mid pipes (just downstream from the cats) is the most difficult part, it can be difficult to separate the X pipe from the mid-pipes.
You'll have issues with banging /clunking if you don't have the pipes pushed up off the prop shaft tunnel cross brace (dog bone thingy), then tighten the joints/connections. This will ensure adequate clearance over the prop shaft tunnel cross brace.
Basic hand tools needed: P'blaster/spray penetrant, 1/2" drive socket set, dead blow/rubber mallet. Air tools make it much easier.
Pretty easy to do if you can change spark plugs and your own oil.
Check for adequate clearance, you will likely get clunks and rattles your first time...
