1 - 4 of 4 Posts
Can I use r/t shocks with 3.5 springs? is there any difference between the r/t and sxt shocks at all? i have sxt with r/t springs and shocks, the fronts are acting wierd and sits higher than stock 3.5. im thinking about just changing the front 2 springs. thanks.
spring rate
These vehicles do not weigh the same and as such each uses a different spring rate. If your engine weighed as much as the hemi you would see your front end drop to the proper hieght.
Look up spring rate on wikipedia.com
1 - 4 of 4 Posts
