While getting an alignment on my car, I was told that my camber was off and I would need to replace the upper control arm with an adjustable one, and it would be $425 installed. They also informed me that I should do both the left and right ones to fix this properly, which would come to $850.
Year and half ago I hit a street light that was down across the highway
. No immediate problems, but I've had residual problems ever since. This appears to be one of them. I don't know anything about alignments, but I've looked around and found 'camber kits' such as this:
http://www.carpartswholesale.com/v5...r_Rear-comma-_Upper&sc=Product+Listing+Page:1
Is it possible that I can use this as a cheaper solution instead of replacing the upper control arm with such an expensive adjustable replacement? Are these camber kits and/or upper control arms hard to install? Is the camber mis-alignment a sign of deeper problems?
Attached is the numbers from the alignment, and the estimate for the upper control arm installed. It's a 2008 SXT Charger. Thanks!
