So a few months or years ago I had some caliper noise. Always heard like a loose metal sound in the front. Like this:
Noise from caliper: http://youtu.be/xzmBJemdDUk
Changed my pads Thursday and noise is gone. When taking my calipers and caliper brackets, I noticed a lot of rust special in the caliper guide bolt (I guess that's the name). I greased it up. Wondering if that is part of maintenance to the brake system? Is there a routine maintenance for calipers and caliper brackets? Has anyone ever experienced this? Because I had the rattle WAY BEFORE there was any need to replace calipers. And the ONLY reason I did is because the pads were cracked because of the heat. There was at least half the pad left. Any insight would be greatly appreciated. Thanks in advance.
