I just installed my AFE 2 CAI and my gas mileage went from 19.5 to 17.5 has anyone had this problem? anyone anyone Buller?:nervous s
If you broke the sensor you should get a CEL...should....if you do the fuse 11 and still have problems have your dealer hook up his StarScan...it will tell if the sensor is working....but I bet the problem goes away either right after the fuse pull or within a few days....I'll try to reset HAL and take a good look at the install. if I broke the sensor wouldn't have a check engine light or something like that? cause I have no lights.:smoke:
Not a true CAI but if you run a DashHawk you can monitor the intake temp...at hwy speeds the temp is ~same....his gas mileage should not have changed based on my experience with both the 5.7 and 6.1 hemis..Is it a true CAI or a short ram intake? If its the latter, your loss in economy could be due to all the hot air your drawing in instead the air from outside of the bay as the stock airbox does.
