hello guys, im new to the forums. i recently bought an 08 dodge charger rt police model, the car has 112k miles, ive noticed some bubbling in the radiator reservoir tank, it appears to be coolant flow coming from a hose into the reservoir, this might be a stupid question but is this normal? i posted a video on
video: youtube.com/watch?v=v53_3xKH9fA
It's not normal. There shouldn't be air in the coolant system. Normally this means there is a damaged hose pulling in air or worse a failing head gasket.
Are you consuming any fluid?
Is not consuming any coolant at all, it's always at the cold fill mark and when the engine is at running temp The coolant level rises up to the top of the reservoir and you see the upper reservoir hose dumping coolant into the reservoir with pressure. You have to watch the video in case you haven't because someone else told me it was normal.
