1 - 11 of 11 Posts
So I’m pretty pissed off. In order to get the info off my pcm from my ‘18 R/T in order to request the swap with Diablo the plastic locking things on the connector plug snapped right off when I went to pull it off to get the info off the stickers.
Funny thing, it isn’t a red one like I see all over the internet. I suppose the excessive heat with it being a Florida car caused it to be brittle and it must of been replaced already once before.
Is this the right replacement and how do I replace it? The lever thing broke in the locked or mostly locked position. I swear the older I get the worse I am with my hands.
https://www.mouser.com/ProductDetail/TE-Connectivity/1924779-1/?qs=38Qq1exbXqd5qGgdJMBQyg==
WOW!. Someone with the same problem I have.... The previous owner or a dealer broke mine I guess. I bought a PCM & tuner & been sitting on it for almost 2 years because when I tried to pull it out, same thing, got one & the other is broken. Can't get it off & if I could not sure I could get it back on.
Well I ordered 3 of these and will get them by Friday. I guess I’ll have to figure this out since it sounds like no ones attempted a fix?
I went ahead and ordered my pcm swap with Diablo so cross fingers!
Discussion Starter #4
So they got here already and look just like the red factory units. Once I get the car back from the off-road shop installing my rock and backup lights I’ll give these a try. If these are indeed the replacements I’m probably going to buy a dozen more.
293451
Let me know how do you replace them? The bottom connector is my broken one.
Discussion Starter #6
Will do brother. I think I figured it out. I hope to get my car back tomorrow so I can put that and my leather Hellcat door panels on this weekend while it’s sunny.
Great. I just ordered 1. If you can please PM or post how you replaced it, when you can.
Thanks
Discussion Starter #10
Thanks
A flat head screw driver pops it off here:
293669
When you put the new one on you’ll need to use something thin and long to push each of the sliding locking clips here and don’t forget you’ll need to look at the other end to ensure they slightly stick out the other. I used along skinny flathead screwdriver:
293670
When putting on the new one make sure the lever is as far back as you can go then use the rear tabs to slide in the other side of the connector here. Don’t forget to double check to make sure no wires get caught outside of the connector and get cut.
293671
Hope that helps!!
Yes. Worked like a charm!
Hey man i was hoping u may be able to help me... I just now had that happen to me as I was swapping out my pcm with an unlocked one from Diablo.. only difference is it happened to me while I was trying to tighten it back onto the unlocked pcm and now that it snapped it doesn’t fasten as deeply into the pcm as the one connector does if u know what I mean and when I went to put my car into run mode I had a “ check electronic stability system” and I have a battery icon on my dash ... I even tried going back to my stock pcm and it’s the same issue now.. idk if the trinity tuner drained my battery or if my pcm and electronics aren’t working right cuz it’s not somehow fully connected but when I try to start my car it won’t start snd my performance pages on my Uconnect are missing too I have a 2018 charger scatpack
1 - 11 of 11 Posts
