1 - 1 of 1 Posts
Hey guys/gals,
So I am in the middle of my Brembo swap on my 2018 RT. The fronts are all done, minus bleeding. I have the drivers side rear knuckle off and my issue is the parking brake cable. I read Juniors write up, which was extremely helpful, however I do not have access to 2 of the bolts to remove the hub from the knuckle while on the car. With that being said, I cant install the parking brake cable while the knuckle is on the car, as there isnt enough room between the knuckle and hub. So my only option is to disconnect the parking brake near the differential, where it meets the cable that goes up front. Is there a trick to that, It appears like the knob at the end of the cable just slips in but I cant get the old one out. Any advice would be helpful.
Thank you guys!
1 - 1 of 1 Posts
