For a limited time, get free shipping in the continental USA and 50% off shipping to Canada!
Baer introduces the ALL NEW Pro Plus brake systems featuring our brand new 6P 6 piston calipers and 14" slotted, drilled and zinc washed, 2 piece rotors. Attractive styling at an affordable price, Baer's new Pro Plus front and rear brake systems are sure to please the most demanding owners and impress the most critical on-lookers!
The 6P calipers employ the same pad as is original equipment on Corvette C5 and C6 applications. This high performance pad style is available in almost limitless compounds ranging from basic dust-free street use to full race than that of any other pad.
Utilizing the same technology often only found in competition motorsport brake systems costing thousands more, Baer has created one of the most powerful brake systems for the money ever offered! With features like internal cross-over tubes, standard powder coated finishes in Red, Black or Silver, and slotted, drilled and zinc washed rotors in 14" diameters, the NEW Pro Plus brake system is sure to look as good as it performs! Systems contain all necessary mounting brackets and hardware, and even come with stainless steel braided hoses. All components meet DOT specifications and are street legal in all 50 states.
Designed to fit most factory or popular aftermarket 17" or larger wheels. To verify fit in any wheel, please download our brake template to check your wheel for clearance. Note: Baer recommends that you check any wheel at any diameter for clearance as wheel center designs also have an effect on caliper clearance. Our rear kits also come with 14" 2-piece rotors and will work with your existing parking brake "drum in hat" configuration. (Note: Rear calipers are physically the same externally, but feature smaller diameter pistons for proper system balance.)
FEATURES:
Please click below to go to the ordering page.
Baer Pro Plus Big Brake Kit - 05-09 300C, Charger, Challenger, Magnum
To see a full listing of our brand new items, please click here.
To see a full line-up of our current sales and specials, please click here.
FEATURES:
- State of the art, leading edge technology, 6P calipers
- Calipers use the same pads as the Corvette C5 and C6
- Meets full DOT specifications
- Smooth contours and your choice of standard Red, Black or Silver powder coated calipers
- Two piece rotors, standard with slotted, drilled and zinc washed finish in 14" diameters
- Costs thousands less than systems using comparable calipers with similar technology
- Increased brake torque, fade resistance and improved pedal feel
