on stock rotors and pads(i think.. car was used and havent taken a close look)
comin down from anywehre above 80 quickly results in some pretty massive shaking of the car. it can be really bad comin from 120 and down.
you can feel it if you know what your looking at if u brake hard at jsut about any speed tho.
anyone else experienced this?
one of the rotors was machined(lathed) once by the previous owner, and im thinking about having all 4 done to make sure theyre even, but at that point it will probably not be possible to do it again should a problem occur and ill need new rotors(which may not be bad anyway. but im poor)
is the problem with the rotors or pads would you think? easiest fix? goto the dealer(im still in warranty, is this warranty?) or get soem Red Stuff if pads?
thanks!
thanks!
