1 - 20 of 22 Posts
Yesterday evening on my way home from work I was passing through a construction zone. We all had to slow down, I was going about 20mph but I was on the brakes when thud I hit some kind of deep grate in the road. After that my brakes were soft, meaning the pedal almost has to travel to the floor before they engage. Now I have had this happen before about a year ago on my to work but the road conditions were wet and I was accelerating out from behind a tanker truck from a stop light. The tires spun and I was in a bit in a drift but nothing crazy. After that when I went to stop, to my surprise no brakes... but as it turned out I just needed to press harder and they engaged, much like my current situation. After a few pumps at the stop light it they didn't return. I got to work parked and at the end of the day got back into the car the brakes were fine. Now in my current case the brakes are still soft even after waiting over night. This is a 2011, any thoughts?
· Premium Member
Zal:
I would start by checking your brake fluid level. If it looks dark, consider new fluid and bleeding the brakes of course. I would also do a visual check at all 4 corners to be sure there is no physical damage that may have occurred.
Don
Don,
Thanks for the reply. I stepped outside and checked the level and it seems fine. Haven't checked the color though. When I get home I will take a look at the color and the look at the calipers themselves. I would think if I had leak, overnight something would have puddled right? Also the brakes work fine and there's no noise they just don't engage until I am close to the floor. If I had a leak would the performance degrade pretty rapidly? Juust going to keep my distance a speed down on my way home, yupp I am about to be that slow guy everyone's pissed at haha.
Kind of an out there one, but check for loose wheel bearings. If one is loose and pushing the pistons back further into the caliper you could get more travel from that.
Hey fellas I just checked the master cylinder and there's no leak. Nothing visible near the calipers either and the fluid level is at max fill. I'm blown as to what this is.
As I was leaving work I decided to slam on the brakes from 25mph. The car stopped on a dime, no abs kicked in though but I also didn't drag the tires either. I still had to depress the pedal almost all the way down to the floor though. No lights on the dashboard or error codes lurking.
How do I check the wheel bearing? Would there be any other symptom of it was loose?
Sent from my SM-G965U using Tapatalk
Good point. Yes the pedal returns and if I pump the brakes while the car is off the pedal is stiff until I turn the car on. Does that help?
If I needed a bleed would a larger than normal bump in the road set that off though?
You may have had air air bubble hiding in the ABS (usually caused by bleeding the brakes but not the ABS) when you hit that big bump the bubble went on a little trip throughout the rest of the brake lines seeking out the highest point which is usually in the rear brake lines (this is why you are supposed to have the rear sitting 5" higher than the front when you bleed the brakes)..... so long story short, do the least invasive &cheapest thing first: have the brakes and ABS bled.
Fellas, haven't bled the brakes yet but I heard with ABS systems you have to go to the dealer so they can activate the ABS with the computer in order to "shake" the air out. Is this true?
Did a flush today didn't fix it. Ended up replacing the master cylinder and that was the problem. Now my brake light is on but no code can be found with a scanner. Brakes work great and ABS kicked in fine for my high-speed hard brake test. Any idea why the brake light on the dashboard would illuminate after a master cylinder replacement?
I'm not thinking anything other than that you need to use an abs capable scanner to tell you why it's angry. Who knows, it might just need something cleared since the master was replaced.
There is a float in the master that pics up low fluid level (one in the windshield washer tank too, but a different style) Try the old reliable "disconnect the battery" trick and let it sit 10 min or more... Somebody else on the forum had an issue with the light and it turned out to be the adjustment of the brake light switch (on the brake pedal arm).
Turns out that the switch is self adjusting and has to be replaced when something drastic changes --like your pedal no longer going to the floor:
Glad youre fixed...But hard to understand how the Thud, hitting something on road, had any effect of the master cyl...? Coincidence..?
Exactly..that is why no one suggested that was the problem..I've never heard a a big whump killing a master cylinder, but there is a first for everything.
Discussion Starter · #19 ·
Truly bizarre. Was super busy today so I wasn't able to disconnect the battery yet so I'm just rolling around with the brake light on the dashboard. By the way extremely bright while driving at night
2013 R/T
If a battery disconnect doesn't work you need a more advanced scanner/code reader. Most run of the mill readers will reset most codes but some ABS codes and HVAC codes are harder to access.
Some dealerships will do it free, some will want an hours labor, try a Firestone or major repair shop that may have a Snap-on scanner.
Good luck, let us know how you come out.
1 - 20 of 22 Posts
