1 - 14 of 14 Posts
What year and model car do you have? Do you have any special packages (eg, Blacktop)?
For most 2011+ Chargers, Touring Suspension was standard on SE, SXT, and AWD models.
For most 2011+ SE and SXT chargers, front brakes were 12.6.
If you have an R/T (including R&T), you have the performance tuned suspension. R/Ts (RWD) have 13.6" brakes in front.
I quick way to check to see if you have a Road & Track, is to check the R/T emblem on the front grill. If its red, its an R & T.
Discussion Starter · #12 · (Edited)
Well guys, I finally got everything ordered:
Moog R series Control arms, upper and lower on both sides.
Moog sway bar end links, both sides.
Power Stop drilled and slotted rotors with ceramic pads all the way around.
Koni orange shocks all the way around.
Eibach lowering springs.
Finally, Diablo Intune 1000.
Hoping everything gets here by Friday so I can get everything on. Hopefully this will stop my dreaded front end clunk, if this dosnt fix it, I don't know what else I can do (did tie rod ends two months ago) Il let y'all know how it goes!
Thanks got all of your help!
-Adam
Hope it does, but if it doesn't, you've got company. More than a few folks get this at some time. My memory fails me on this, but I want to say many are related to the end links. In any event, if it returns, SEARCH can be your friend.
Good luck!
Good luck!
Thanks buddy!
And yes, end links do seen to cause a lot of the clunks. But I have also seen a lot of ball joints and tie rod ends.
I'm just hoping that by knocking everything out at the same time, I can let my mind have some peace knowing everything is new. Especially since I'm lowering this heavy beast.
1 - 14 of 14 Posts
