1 - 20 of 24 Posts
· Vendor
BLACK FRIDAY SPECIALS
Many are asking for what black Friday thing we were going to do.
Well we are offering 20% off everything we make from 10:30 am to 2:30 pm Pacific (5:30 EST) 11/28.
ACES IV
QuantumBlue Lubricants
QuantumBlue HP Gold Coolant
Give us a call, pm us and call us. :beerchug:
Regards,
Brian
BND Automotive LLC:driving:
440-821-9040
www.bndautomotive.com
· Vendor
Discussion Starter · #2 ·
The sale has ended. Thank you all who participated. Great to hear from so many of you! :rocker:
Regards,
Brian
440-821-9040
· Vendor
seesh i missed this.
looks like i can import oil to my country
i have sent u a pm brian
Yea, I am working on that for you. Would like to get that and ACES IV into your hands. Will be back to you shortly.:beerchug:
Regards,
Brian
440-821-9040
Hey Brian,
Any chance my ACES / ps fluid went out. Thanks,
Andy
· Vendor
Doh, should have checked the forum! Was caught up in all my other shopping, LOL.
· Vendor
Well, we have extended the November specials till December 15th so you can still get in on those which are really good too. Lifetime filter, free transmission flilter with trans fluid pan drain and fill etc. :beerchug:
Regards,
Brian
440-821-9040
Andy,
Yes, as a matter of fact, it is on the way! Enjoy!:beerchug:
Regards,
Brian
440-821-9040
Thanks a bunch.....if I can I will order some oil by the 15th to be able to take advantage of the "filters for life"...I just checked my records, and I am about 12k since last oil change!! Yikes!!
Hey Brian,
BTW, you don't happen to have a tracking number, do you? Thanks,
Andy
· Vendor
Also, Brian....is it possible to ship / charge to my debit card 2 galllons of QB Oil / filter on the 15th? Let me know.....
Andy
(808) 386-2326
· Vendor
Andy
(808) 386-2326
Andy,
No problem. We will ship it out and use the same card/address to get you the two gallons and the filter!:beerchug:
Regards,
Brian
440-821-9040
· Vendor
Discussion Starter · #16 ·
Where's the December deal on Aces IV?
1) ACES IV Special: 1 gallon ACES IV Treats 770 Gallons of fuel @ $241.00 - Regularly $271.00 - (Save $30.00). 1 Quart ACES IV treats 192 gallons of fuel @ $68.60 - Regularly $81.85 - (Save $13.25).
1a) ACES IV 2.5 gallon container - Treats 1925 gallons $580.00. (Save 97.50) Comes in an industrial container. People have been asking for a bulk size ACES IV a long time and so we did it for those who now want it.
Here is all of the specials till December 15th.:bigthumb:
http://www.chargerforums.com/forums/showthread.php?t=242994
Regards,
Brian
440-821-9040
· Premium Member
I honestly don't think I am going to be able to continue to afford Aces IV as much as I'd like to keep adding it to my vehicles. If my calculations are correct, it is going to cost me approximately $6.00 more with each fill up. I have two old Dodges; One has stock 1980 360 4 barrel and the other is a new stroked 410 c.i.d. smallblock. If it matters, the stock 360 has a flat tappet cam and the stroker is a roller setup.
If I can only afford to use it on say two of my cars, which two would benefit the most? I might not even be able to continue that but would like to know in case I am able.
Thanks!
· Vendor
Discussion Starter · #18 ·
Thanks!
What you are forgetting is that ACES IV contributes to between 8% and 10%
fuel economy. So if you are paying 2.80 per gallon of premium and you are adding ACES IV @ .31 per gallon and it is 19 gallons here is how the numbers work.
$2.80 x .08 = 22.4 cents
22.4 x 19 = $4.26 in savings.
ACES @ .31 x 19 = $5.89.
5.89 - 4.26 = $1.63 per tank of fuel and all the benefits beyond that are free....detergency, lubricity, ignition improving etc.
Obviously the 360 4bbl car was put together when you had 300 ppm sulfur as a high pressure lubricant for the rings and the valves/guides. You would definitely want to run it in there.
On the new stroker, ring wear and bearing wear are important things to keep from having. You aren't going to drive it like Miss Daisy....LOL.
For $1.63 per tank net, it is in my mind a simple choice to use it vs not using it.
Give me a call and I can see if there is anything I can do to assist you on this order.;)
Regards,
Brian
440-821-9040
Andy,
Regards,
Brian
440-821-9040
Thanks a lot, Brian.....Merry Christmas :beerchug:
· Vendor
Discussion Starter · #20 ·
Your Welcome. You should have received the tracking number for the shipment.
Merry Christmas to you and your family!:beerchug:
Regards,
Brian
1 - 20 of 24 Posts
