Fuel Rails, I need some Billet rails with -8 fitting to handle the increased HP
thanks
thanks
thanks
If you have a 5.7 DO NOT go with CPR fuel rails, you will need to grind down your manifold to make them work, and they still do not fit properly. There has been documented proof of CPR admitting they had a design flaw when making theirs. Go with the BT or DCX rails, no CPR. They have been a nightmare for me for 8 months now.here you go...as Black 08 said we have CPR rails, we have been using/selling these for 2 years for the LX cars and much longer for other makes and models.
Here is a link:
http://www.bmcspeedshop.com/product_p/cpr4004001.htm
We also have custom braided fuel crossover lines available as well
CPR re-designed their rails a while back, due to feedback from a couple people.If you have a 5.7 DO NOT go with CPR fuel rails, you will need to grind down your manifold to make them work, and they still do not fit properly. There has been documented proof of CPR admitting they had a design flaw when making theirs. Go with the BT or DCX rails, no CPR. They have been a nightmare for me for 8 months now.
That's just an example of what they will look like. Final design is not done. Trust me, when you see these rails, you'll understand why you need these, lol.Ken,
the ones you linked....
why do they look so similar to the 2009 5.7L fuel rails?
I guess we've all had different experiences with the CPR rails. I have a 850+ hp Mustang with CPR rails and zero issues for several years. We have about 3-4 customer cars with 800+ hp Mustangs also with CPR rails and, again, no issues. I don't know why ours would work fine and others not, but I just wanted to mention that CPR rails have withstood just fine here.Beware of fuel rails with welded on mounting tabs. I've used those in the past and almost all of them fatigued over time and cracked. Actually had a set let go at 130 MPH spraying fuel all over the windsheild of the car.
And that was at the ford fuel pressure of 40 psi. DCX fuel pressure is much higher. Not saying this to pump our rails up but this is a huge saftey issue and if I didn't share that info I would feel bad if someone had an issue with them and burned their car to the ground.
We had a metalugist take a look at a few sets and in most cases (but not all) a different grade of aluminum was used for the tab as compared to the rail making it more difficult to get a good weld. But even on a set that had the same exact aluminum, there were hairline cracks on all 4 tabs.
Ken
gotcha.That's just an example of what they will look like. Final design is not done. Trust me, when you see these rails, you'll understand why you need these, lol.
Don't want this to turn into a vendor war, but I used to sell CPR starting 6 years ago. Every set out there cracks. I'm not asking you to take my word on it. Look them up on all the Ford boards.
Why do they always show them pretty side up.....I would like to see the injector bungs.Are they deeper than the last generation rail cause that was the problem.The injector would not sit deep enough in the rail half the time.CPR is about to release polished, all billet rails for the 5.7, 6.1 that have solid billet tabs (no welding), so for anyone concerned about that, in 1-2 weeks we will have these ...
Price: $239.88
More information: http://www.chargerforums.com/forums/showthread.php?t=101954
Yea the injectors dont sit in there snug at all. the 2 little screws that hold on the half covers are basically your only saving grace with the CPR rails. The fact that they dont sit down into the injector properly, and the fact that you need to grind down the 5.7 manifold to make them work, make them a PITA. I hope the new CPR rails change thisWhy do they always show them pretty side up.....I would like to see the injector bungs.Are they deeper than the last generation rail cause that was the problem.The injector would not sit deep enough in the rail half the time.
gotcha.
well they better do more than look pretty for 300 big ones.
they gonna be tapped and ready for front crossovers etc?
