1 - 11 of 11 Posts
I have a 2012 R/T with the stock 18 inch chrome rims. I was looking at getting 20 inch rims
with different sized tires. I want to go wider in the front but don't know how much I can increase without rubbing or not fitting. I was looking at 275 in the rear. Would a 275 fit in the front or should I stick with something smaller? Right now it is 235 all the way around.
Thanks!!
A 20x9" wheel will work well; it was the OEM size for SRTs prior to 2015. 245/45s or 255/45s tires are recommended for this wheel.
If you want a staggered setup, a 20x10" or 20x10.5" could be used in the rear with 275/40s.
Thanks!!
I have 275 40 20 all the way around with 20 by 9 rims with no issues.
Awesome I'm looking at getting the viper wheels with NITTO INVO tires
That is exactly what I have. 20x9 viper reps wrapped in 275/40/20 all 4 corners in Nitto Invos. Nothing else needed/no problems. Did this set up about two months ago and it is AWESOME.
[iurl="http://www.chargerforums.com/forums/attachment.php?attachmentid=170073&d=1428733277"]
[/iurl]
That looks awesome. I will probably end up doing the machined face with the black insert. How does it drive with those tires?
Correction : Nitto MOTIVOS not invos.
I put on about 20k miles on the ones that came with the car new. After switching over it was unreal. So much better in the rain. I am able to take corners with a lot more confidence and rarely any wheel spin unless its cold or rainy. Highly recommend them. Worth every penny. I got them from my local Discount tire.
1 - 11 of 11 Posts
