1 - 6 of 6 Posts
Has anyone done the big 3 ground wire upgrade on there charger? If so a good write up would be helpfull. Thanks
I'm in the process of doing it right now... I'll snap a few pics.. Its a pretty easy process... On the charger you really only need to do 2 of the 3. The wire from the alt to the batt is already 1 gauge. no need to change anything with it. just upgrade the ground to 0 gauge from the battery post to the chassis. Then 0 gauge from the motor to the chassis and your done. make sure it is a non essential bolt.. it doesn't hold a gasket or fluid.
hope this helps.
O.K. I got the first one done but need some help with the following.Then 0 gauge from the motor to the chassis and your done. make sure it is a non essential bolt.. it doesn't hold a gasket or fluid.
Thanks
sorry for my ignorance but what is the benefit of doing this?
I'm interested as well.
It helps your charging system. Since your charging system is a big loop. by upgrading all 3 things helps it tremendously.
1 - 6 of 6 Posts
