Camshafts, as in two. 3.5 is a SOHC. Like kraut said, there literally is nothing much anymore for the 3.5; it's been out of production for 10yrs and was never really a hot rodder's choice. You say you want a "fuel efficient model", yet you wanna modify a 250hp V6 in a 4100lb boat lol. In 2010 the 3.5 was EPA rated 17/25 for fuel economy. The 3.6 in the 2011 was rated 18/27 and that's with the 5sp; a 2015 3.6 with the 8sp? 19/30. Between the newer design, VVT, DOHC, the old 3.5 (that dates back to the 90's) won't ever match it for power or economy.I can literally buy a brand new transmission and camshaft and have them installed for less money than it would costt
Very late, but answers on this form are just misleading. If you are looking for a Chrysler motor to push, the 3.5l is the one to do. It is the only Chrysler motor in the last 20 years that have a fully forged top end. HEMIS can't say that... These motors can handle 12psi boost right out of the box. Inertia makes cams for this motor and have dyno tests proving 25whp gains, and an extra 8hp with the ported throttle body. They also make a 4.0l stroker kit. Pair these with longtubes, and performance heads and you are looking at 400+ horsepower from previous builds. But you will be looking at $5,000 dollars to get to this range. (Not to mention the supercharged versions make 550whp+ LOL)Im looking for a cam that will lower the torque curve. I want more low end torwue
Not to mention the 3.6l is way less modder friendly - integrated cams and headers, locked ecu. You can only slap a 8k supercharger on it from RIPP. Don't let anyone tell you not to push this 3.5l. The only difference vs v8 is the price; the 3.5l is cheaper to have worked on. You can always push HEMI power out of this engine, because it is a HEMI! Yes, hemispherical cylinders is the only thing that makes it a HEMI... The RT's weight 4100 and 3.5l weighs 3700, so there's a bit of weight advantage there... Same tranny too! Unless it's 4 spd... Sigh...Very late, but answers on this form are just misleading. If you are looking for a Chrysler motor to push, the 3.5l is the one to do. It is the only Chrysler motor in the last 20 years that have a fully forged top end. HEMIS can't say that... These motors can handle 12psi boost right out of the box. Inertia makes cams for this motor and have dyno tests proving 25whp gains, and an extra 8hp with the ported throttle body. They also make a 4.0l stroker kit. Pair these with longtubes, and performance heads and you are looking at 400+ horsepower from previous builds. But you will be looking at $5,000 dollars to get to this range. (Not to mention the supercharged versions make 550whp+ LOL)
Did you just join the forum with your blank ass spam profile JUST so you could comment on an almost 3 yr old thread....?Not to mention the 3.6l is way less modder friendly - integrated cams and headers, locked ecu. You can only slap a 8k supercharger on it from RIPP. Don't let anyone tell you not to push this 3.5l. The only difference vs v8 is the price; the 3.5l is cheaper to have worked on. You can always push HEMI power out of this engine, because it is a HEMI! Yes, hemispherical cylinders is the only thing that makes it a HEMI... The RT's weight 4100 and 3.5l weighs 3700, so there's a bit of weight advantage there... Same tranny too! Unless it's 4 spd... Sigh...
Know, super funny cool story. I have some Pre-Production 1G 3.5 Cams in boxes with Carrol Shelbys Business address on them.Did you just join the forum with your blank ass spam profile JUST so you could comment on an almost 3 yr old thread....?![]()
