So this is new. My back up factory camera started flickering on my Uconnect camera and only works when it feels like it. Not normal symptoms for bad wiring but figured I would reach out before I bite the bullet on getting a replacement lense.
Symptoms;
Sometimes the camera works fine.
Sometimes (now most times) when I put it in reverse, i get black screen with flickering. After a few minutes leaving it in reverse, the image reappears clear.
Sometimes, when I put it in reverse, the image is very red. Still works but the color is red as if the color spectrum is off. This is what led me to believe it is the lens itself and not a bad connection.
So before I commit to buying an expensive replacement camera lens, has anyone had this happen and can offer some help?
So far I have tried disconnecting the wiring and using contact cleaner to clean but no change.
Thanks in advance.
Symptoms;
Thanks in advance.
