Just some things Ive lerned about about autostick from my experiences:
- In 3rd and 2nd gear, Downshifts are NOT smooth unless you are shifting at 1000 RPM or lower. If you cant get it right, let the car downshift when stopping/slowing
- 3rd Gear is the highest 'slow down' gear. 4th and 5th wont really slow you down.
- when racing it is best to stay in 1st for a short amount of time.. just enough to get the car moving, then shift early to 2nd - and stomp it.
- Another way to get out out of autostick mode is to up-shift to any gear, and hold the stick to the right. This will set you back to (D)rive
- If you're in (D)rive, and you need a quick boost, you may try to downshift. When you downshift from Drive, you do no downshift at all, you set the transmission to autostick in the same gear you were in. If you need the burts, downshift in advance to get to the autostick, then downshift again while stomping the bad boy. Depending on what ger you end up in and how fast you're going, the boost may be minimal - but it will stil lbe enough.
Edit: Typos
