1 - 6 of 6 Posts
Are these available for the LX body? I see 3.09's are out there, but, I'm wondering if the 230 3.07 in my AWD Pursuit can be replaced with a LSD unit. Do they exist?
Greg
My car is AWD. Front diff is 3.07. Wondering if a 230mm 3.07 rear LSD is available. They have to be the same ratio's.
Greg
No, don't think it's available and don't believe they have to be exact, it's only a .006% difference, you could have that with tire wear. And didn't the earlier Chargers use a 3.07 front and a 3.06 rear?
Discussion Starter #5 (Edited)
Here's the next question then. Are the 230mm diffs the same design? Can a 3.07 ring and pinion be swapped into a 3.09, 3.70 or 3.90 LSD case? In other words, can I roll my own? Anyone know.
Greg
I have heard that the ring and pinion gears are welded to the carrier but a 3.09 Demon guy said the 3.09 was bolted in, so not sure.
I know Dodge doesn't service these parts individually, they would just swap out the whole chunk.
So gonna have to find somebody like Randy's ring and pinion and see what they know.
1 - 6 of 6 Posts
