1 - 20 of 27 Posts
I have HID's and hate wasting an ignition when I unlock my car multiple times a day.
I do not have EVIC....
Is there a sequence or can the dealer do this for me?
hey sLOWDOHC you are trying to turn off the headlights from comin on when you unlock right... i know that you can stop the flashing parking lamps from flashing... ive been tryin to find something to turn the headlights from turnin on when unlockin also.. i also have HIDs and i hate it when they turn on just for unlockin your car..
yeah exactly. the ballasts will only ignite so many times (but well into the thousands I guess...) and I hate using them for just unlocking the damn car.
When I press my unlock once my lights dont come on... only when i press it twice
well my headlights sometimes turn on when i press once on the unlock also... so me and sLOWDOHC and im sure other folks want to turn off that feature....
maybe its the way the unlock sequence is programed then.
Ive read theres way to have them all unlock at one press of the button or dr door, than the rest...
but as of now, its one hit for dr door, and another for the other 3....
The instructions I posted were from section 2, page 23 of the 2006 LX owners manual. It is titled "To Turn Off "Flash Lights On Lock/Unlock".
It should work for you.
yea it does work but thats to turn the flashing lights on and off.. we are trying to turn of the headlights from comin on when unlockin..thanks by the way
Funny we both seek the same. Ok here is the Low Down. We can't turn them off; (not as of yet) I am still searching. Since we have Hid's the afore mentioned threads do not apply to Hid's only stock lighting. I took my R/T to my local dealership where I am tight with the Service Manager and even the starscan can not turn them off. Simply put they I guess they are controlled via ballast and different relay's. I am trying to find a way as soon as I do I will let you know and others as well.
Discussion Starter · #16 ·
Awesome, thanks.
Im wondering if major surgery is needed...Honestly, Im willing to take it there...:)
I wonder if this is a BCM thing, and a new lead from the headlight switch itself to the ballast relays would do the trick...
My lights stay on automatic so I dont know, but if you have the light switch turned to off, do they still turn on with unlock?
Also, ive always wondered, Does the auto headlamp function still work once you install HIDs? If not, how do they turn on / off, through the factory light switch or a seperate switch that comes with the kit?
you could do that with a switch.
im going to go play with my evic now, if you need me ill be outside turning this setting on and off ;)
1 - 20 of 27 Posts
