Hi all, for the record I did do a search, found a couple similar posts, and I do apologize but can't bring myself to going through 488 theeads....
That being said, I have a 2017 charger pursuit, probably an se model. 130k miles, 7600 idle hours not that it matters much, but it's been noted.
Out of the blue, drivers side only blows heat. It will go through the different modes, defrost, vents, floor etc. The passenger will blow cold or hot. But driver will not change temp regardless.....
Engine off in my garage (quiet) I can hear the mode select actuator moving, and I can hear the passenger temp blend door moving. I cannot hear the drivers side clicking or doing anything.
Not sure if it's completely bad, pooped a fuse, I assume they're all tied together.
3 days ago I found a mouse nest in my wife's 2014 grand cherokee under the tipm/under-hood fuse box..... maybe they got to my car, although I don't see any signs of poop, or nesting, no other issues with wires chewed, check engine light is not on.
Anyone know of a fuse, or a video of these newer chargers on the drivers side. I'd like to pull the plug to see if I even have power to the actuator. Not ready to pay the stealership a kidney to fix a $5k car.
Again never heard any clicking prior to this....
Thanks for any help.
