I have to 12" subs and a 1000w amp and i have figured out where to mount eveything and where im going to put the converter and stuff but what should i use for the remote wire?? Ive been told to tap into the cig lighter but isnt it constant 12v?? Do i need 1 converter for the rear deck or two?? Any info will help
I used a PAC-TrunkLoc line output converter with a remote trigger output that senses audio signal which can be used as a remote for your amp. I used this ran to a switch which replaced the cigarette lighter. I am not sure about the cigarette lighter as a source but I know there are several spots in the rear fuse block that are accessory(on/off with key). I used the converter tapped into one of the rear speakers and it will fade with the rear speakers. I have done quite a bit of audio changes so if I cap help with anything else.
reply
everything works great finally found that converter hooked it all up and sounds nice now i gotta work on mids and highs
I use the accessory fuse in the rear box...
