1 - 9 of 9 Posts
I have a 2015 Dodge Charger SRT 392 with the active dampening system. I went to the drag strip yesterday after picking up some new Forgestar D5's and 28 inch Mickey Thompson ET Street R's and ran a couple times. Car performed amazingly and was cutting low 1.6 60 foots all day in bad DA leaving off idle. However, on my way home, about 15 minutes after leaving the track, I got hit with a "Service Active Dampening Suspension" message and locked me into sport mode and haven't been able to figure out what happened or what broke or why. Does anybody know what might have happened or why it might have broke and what i can do to fix it before having to take it to the dealership?
Disconnect the battery in the trunk for 15 minutes. (Negative terminal). Weird things happen to the electronics every time I hit the dyno or track for some reason. Resetting the electronics seem to fix my gremlins
I tried pulling the negative terminal last night for about 5-7 minutes and it still hit me with the service message. I'll go try it again right now and leave it disconnected for longer.
If you do not have a tuner, take it to an auto parts store that has one and see if the code will clear after disconnecting the battery.
Discussion Starter #5
Using the Car's internal code readers it doesn't have nay codes nor is a check engine light on. When I turn the car on it gives me a "Service Active Dampening System" message and when I go to the SRT pages, my suspension is locked in sport mode.
Check the wires and harness at each shock in case a wire got damaged when doing the wheels swaps.
Discussion Starter #7
Just took a quick look through the gaps in the wheels and can see a wire that was worn through on both rear sides I guess from the smaller wheels and big tires. Looks like I will be taking the car to the dealership some time this week to get it fixed.
Discussion Starter #8 (Edited)
291589
291590
Anybody know what these two wires happen to be? These are the two wires that were worn through by my drag radials and I believe they might be the cause of my suspension issue.
Hi Josh, Glad to hear you are working with your dealer for this concern. If you are in need of additional support while in service, please let us know. We can certainly have a case escalated for additional assistance while in service.
Rob
DodgeCares
1 - 9 of 9 Posts
