Below is a screenshot from the Diablo Dataviewer of a short WOT run in RumBee using the Stock Tune, stock shift points, and stock shift firmness. The only changes I made from the stock tune with the Predator were to turn off my rear O2 sensors and to lower the fan settings by ~23 degrees since I have a 180 tstat.
The graph below represents a short WOT run from 2nd gear to 3rd gear. The vertical cursor was placed at the center of the shift (halfway between the peak rpm in 2nd and the minimum rpm in 3rd). ST KR reached 5 max and LT KR was 0.0 throughout:
The blue trace is the Throttle Position Sensor (TPS) and the red trace is the Accelerator Pedal Position (APP). Both of these are shown in %.
Why does the TPS exceed 100% during this data log? I can understand that if the TPS was zero when the APP is zero that the engine would choke from no air flow, but why does the TPS exceed 100%?
Please let me know if I forgot to provide some info...
Thanks in advance. :thumbsup:
