After evacuating and trying to add freon I can't get the AC clutch to engage on my 2008 SRT8 charger, The low pressure gauge after one can installed is about 45 pounds, I would think this would be enough to activate low pressure switch, I tried to find the low pressure switch to jumper it but can't find it, is it in between the radiator and condenser?
Will I be able to access by removing the panel behind radiator?
I looked the AC wiring diagram if I jumper the fan control relay will this supply voltage the AC clutch???
The AC wiring diagram shows 3 wires on the switch, which two wires should I jump to power up clutch????
Any help would be greatly appreciated thanx Bruce
