1 - 2 of 2 Posts
any wiring expects around?
my abs and esp/bas lights are on, Ive tried resetting them by pulling fuses, unhooking the battery. the code I get with the key dance is 1418. replaced the right rear sensor, which didn't help, when i checked with ohms i get 6.5 at the new sensor so i checked all the other sensors they all get about the same amount. as well when i spin the wheel the number changes, which i dont know if thats the correct way but Im assuming that means the tone rings are ok. ive done this on all 4 corners.
when I checked the harness, i found issues. on the right rear I found that if my ohm meters probe's were arranged with the red probe on the supply line and black probe on the signal line I wouldn't get a reading. if i put the red probe on the signal line and a black probe on the supply line I got a reading of 6.5 just like all the rest.
i followed the harness through the truck as far as i could and from the abs module to the firewall and have no found any indications of a bad wire. although i havnt ripped the interior out to follow the harness all the way.
my question is does anybody have a diagram of connector at the abs module so that i can attempt to test it as well is there any where in between the trunk and the firewall that the harness is prone to being pinched or rubbed through at.?
Here is a Dodge Truck forum that sounds like your problem,check it out see if it helps :
http://www.cumminsforum.com/forum/3...s-brake-lights-changed-rear-speed-sensor.html
1 - 2 of 2 Posts
