I was just wondering if any engine parts from the 6.4 are use able on my 6.1
Really? Which ones are compatible?Some... What did you have in mind?
The 6.4L intake manifold is an active intake with long tube and short tube runners that are controlled by the PCM. It is useless on the 6.1L engine. A 2010 5.7L Eagle intake would work but it doesn't flow any better, it just has less heat sink.You could always get the 6.4L intake manifold. Not sure if the 392 cam would be an improvement over the one in the 6.1, but definitely something to look into if it does work. Other than that, I really don't know what else you could use... Possibly 6.4 heads would fit? Maybe?
Didn't even think about any of this....The 6.4L intake manifold is an active intake with long tube and short tube runners that are controlled by the PCM. It is useless on the 6.1L engine. A 2010 5.7L Eagle intake would work but it doesn't flow any better, it just has less heat sink.
As far as the cam goes, the 6.4L cam is designed for VVT so while it is useful on the later 5.7L engines that also have VVT, it is useless on the 6.1L engine which doesn't have VVT.
Just buy performance parts designed for the 6.1L engine. The 6.4L has nothing to offer for it. The 6.4L was built off of the 5.7L engine, not the 6.1L engine.
