Vendor
If you have a 2011 and up 3.6L VVT V6 from Chrysler, we want you to know that you have access and availability to a QuantumBlue Custom Blend that is Ilsac-GF5 and API-SN applicable.
We have been working on the formula for about a year before the 3.6L VVT was released and have come up with a blend that is perfect for these engines.
8.5w32 QuantumBlue High Performance Multi-Valve 3.6L VVT Double Overhead cam Polyspheric Hemi Custom Blend.
We also have the QuantumBlue Ultra HP oil filters to go with it.
Mopar has been recommending a 5w20 for all engines including the 392 Hemi....both with and without MDS. We obviously disagree with this. The 392 if MDS should be a 5w40 QB HP Competition Formula and the non MDS 6 speed should be 12.5w40 QB HP Competition Formula.
However, on the 3.6L VVT engine, they are now.....depending on year...... recommending between a 5w20 and 5w30.
We know that the 8.5w32 will be much superior to either the 5w20 or 5w30 and is fine for everyday use and is good for at least 10k miles of driving.
My wife's 2011 3.6L Pentastar Avenger just had it's last oil change at 12,748 miles!!
Looking forward to continuing to working with all the 3.6L VVT engine owners.:rocker:
Regards,
Brian
BND Automotive LLC:driving:
440-821-9040
www.bndautomotive.com
Vendor
What's the cost? Have a 2013 3.6
The special right now is 2 gallons of the 8.5w32 + the Free QB cartridge filter and gasket kit for $100.00 + shipping. So basically $75.00 for the change with 2 quarts left over.
So you would use 6 of the 8 quarts for the change, use the filter, and then use the other 2 quarts for top off during the 10k mile drain interval.
If you don't use them for the 10k miles, you can then just order a single gallon for the next change and get the cartridge filter next.
As I said earlier, my wife's 3.6L VVT Avenger's last change on this formula was 12,748 miles. It is bulletproof lubricant for these high performance V6 powerhouses!:beerchug:
Regards,
Brian
440-821-9040
