1 - 1 of 1 Posts
I wanted to get a concensus on some information spread throughout several different threads, into one thread... I will update this original post as input and info is confirmed, so all info is in one unified, easy-to-find post.
I have a 2013 R/T AWD Charger
For the AWD platform:
REAR SWAY BARS
- the rear sway bar is the same as the RWD model, and thus can be upgraded, however this requires dropping the rear cradle (Hotchkis, Whiteline, Petty's Garage, Eibach, etc)
Whiteline: http://www.speedlogixstore.com/product-p/bcr15z.htm
Eibach: https://fasthemis.com/i-23835502-eibach-rear-sway-bar-chrysler-300-dodge-charger-2011-2019.html?ref=category:1204066
Hotchkis: appears that rear bar is not sold separately
Petty's: https://pettys-garage.myshopify.com/collections/brand-parts/products/pg-sb-002-pettys-garage-adjustable-rear-sway-bar
FRONT SWAY BARS I am unaware of any compatible front sway bar upgrade aside from maybe the stock pursuit sway bar? (Not confirmed)
END LINKS
- Have not been able to confirm compatible sway bar end links for AWD
SUPER TRACK PACK
- STP suspension upgrade is not compatible
COILOVERS
- Coilovers options include: BC https://www.bcracing-na.com/product/ds-series-coilover-dodge-charger-awd-2007-2016?gfid=p3293-c24861
SHOCKS/STRUTS
- Any other brand shocks/struts for improved performance?
SHOCK/STRUT BRACES
- Front and rear shock/strut braces are same for RWD and AWD (Speedlogix, Mopar, Petty's)
http://www.speedlogixstore.com/category-s/2214.htm
SUBFRAME CONNECTORS
- Subframe connector same for RWD and AWD
Speedlogix: http://www.speedlogixstore.com/product-p/sx-306-5014.htm
Please add your input on what else is available, and what has or hasn't worked for your AWD's.
Thanks fellas
1 - 1 of 1 Posts
