I was told that 245/50/20 tires will fit on a 2012 Charger and that the height would not hit the ball joint above the tire. Is this true?
Stock wheels or aftermarket? If they are aftermarket, what is the offset?2012 Charger SE...wheels are 20x8.5
In order to know if the wheels risk rubbing you either need to test fit or calculate the clearance using the wheel offset.Aftermarket. Not sure on offset. They are Hipnotic Joker 20x8.5 wheels.
