Think there will be any issues with putting 20x10's all around wrapped in 275/40ZR20's? Not looking to mess with lowering, cutting or spacers. Set it and forget it. Hope to hear your thoughts~
I like this calculator. It gives a visual representation of the numbers.Well, the stock 275 wheels are 20x9.5 with +18.5mm offset so just need to figure out what offset you will need to keep the inside of the wheel at the same position while going to a 20x10. The online calculators should tell you this.
I'm looking on Tire Rack atm. I dont see where you can add non-standard wheel sizes to the calculations to determine proper fit. Then again im a newbYes, and read all about it at Tire Rack........
Is that 8mm enough to change the steering geometry? I don't know how much a 1/4 will move things, but the farther out you go from the hub the more it affects your steering geometry and camber angle.The problem with a low offset on the front is that you can and most likely rub on the outside, either the fender or the liner.
I had a set that were +8mm when installed with the spacers to clear the suspension, but rubbed the finder liner on the outside. Just something else to consider.
It doesn't change suspension geometry. I've been doing alignments and tires for a loooong time and racing in some form or another just as long. On a daily driven car, you'll never notice the difference in "scrub radius" changes.Is that 8mm enough to change the steering geometry? I don't know how much a 1/4 will move things, but the farther out you go from the hub the more it affects your steering geometry and camber angle.
Wheel offset calculator
I have not seen this posted here so thought I would share. I found a neat wheel calculator to play with. Just plug in your original or current wheel width and offset, then plug in your proposed new wheel specs and see below how the inner clearance and outer wheel position will change. Using...www.chargerforums.com
There's a lot of places I cut corners and a lot of things where safety isn't a concern. Keeping my wheels (or anyone else's) on the car is NOT one of them lolDAMN! You do quality work my friend.
