1 - 4 of 4 Posts
Hi, I needed some help. I keep getting some conflicting answers. I have a 2020 Scat Pack I want to put some bigger wheels on.
20x9.5 with +15 offset up front to run some 275s
20x10.5 with +25 offset on rear to run 305s
No spacers needed? No rub?
I appreciate any help.
Smaller offset will put the wheels further away from the steering knuckle... IIRC the 9" wheels have a 19mm offset, so 15 mm should probably be fine. Somebody that actually has a staggered set will likely respond soon...
I have 20x9.5 +15 running 275/40/20 in the front and 20x10.5 +22 running 315/35/20 in the rear without spacers and no rubbing.
Tire Rack says 15MM for the 9.5 is good. Secondly, they show +20MM for the rears, so you'll be 1/5", or .20" closer to the fender lip. Secondly, the 305/35 is the smaller in diameter compared to the 275/40 by .3", if that matters .
1 - 4 of 4 Posts
