X2Depends. Some over 20x9 and 20x9.5
x220x9 --- standard 4 piston Brembos
20x9.5 --- w/ Dynamics 6 piston Brembos
I have the dynamics package so I have 6 pistons in front and I think 4 in the back20x9 --- standard 4 piston Brembos
Yes and all Brembo brake cars even Hellcats have the same 4 piston calipers and rotors in the rear.I have the dynamics package so I have 6 pistons in front and I think 4 in the back
I don't think the 8" wide wheels will fit over the Brembo calipers (on either the front or rear). The calipers are pretty wide and I've never seen the four piston ones with anything less than a 9" wide wheel, and the six piston ones with less than a 9.5" wide wheels.Come to think of it, if you want to do burn outs, get the 20 by 8 wheels that go on the RT. You can mount up skinnier tires that will break loose faster and also be cheaper to replace. Don't get 20 by 10 wheels to mount 315 size rubber just to Turn around and break traction On purpose
Here are a couple pics of the four piston Brembos with the 20x9" wide WRT wheels..doesn't look like a whole lot of extra room !!You may have a point krautmaster. But I seem to recall a decent gap between the brembo rear caliper and the backside of the wheel face last time I cleaned the wheels.
The OP probably wants 9inch wheels anyway
Haha, that was me running late to pick my daughter up from school, stuffing my S10 plus between the spokes for a quick pic.What kind of camera do you have?
