I have a 2016 Dodge Charger SXT with 235/55R18 tires. How big of rims and tires can I put on without making other modifications? Thankyou
Biggest factory combo that will fit is 245/45R20's on 20x8 wheels. There are quite a few variations to choose from. Don't try to fit SRT or Scat Pack wheels (20x9, 20x9.5, 20x11). After that you start using spacers or aftermarket wheels.
The OEM hellcat 20x 9.5 fit my 2016 RT with no fuss whatsoever. I also fit some 300C 18x7.5 for my snow tires. The hubs on previous Brembo SRT were indeed a different offsset.
Good thing about the Hellcat wheels is the +18.5 mm offset so even though they are 20x9.5, you get plenty of clearance to the inside.
If you tried to run the 20x9 with the +25.5 mm offset, they would be much closer to rubbing.
The WRT Wheels off the Daytona (Hollander interchange code 2527) are 20x9 with a 19.2 mm offset and also fit without a spacer (warning: they are a bastage to keep clean). With the 245x45x20 tires there was about 1/2" clearance between the tire and spindle, so 275x40x20 might be too wide.
