1 - 20 of 35 Posts
· Supporting Vendor
2015+ Dodge Charger Hellcat DRL LED Boards
Upgrade your Charger Hellcat's factory DRLs with these drop-in RGBW multicolor replacement LEDs! These modules are a direct replacement for the factory-installed LED panels in the 2015+ Dodge Charger. Your order includes a full set of panels, as well as drivers to safely and reliably power them.
From the factory, the halo rings in the headlight are illuminated by small 1210-size white LEDs. Our multicolor board is designed with high-power RGBW LEDs, as a drop-in replacement. You don't have to align and fasten LEDs- this is an OEM-grade solution. Just remove the old panel, and ours fits directly in place, with patent-pending fit and finish.
Made in USA, the replacement panels utilize RGBW LED chips. Each one illuminates with red, blue, green, and 6500K white. The multicolor function allows for full multicolor control using any standard common-anode RGB or RGBW controller (not included).
Remember, this product is not just RGB- it is RGBW! That means there is an LED chip that is specifically white in color, right next to the standard red, green, and blue chips. By using an RGBW controller rather than the standard RGB, you can activate and control the white chip independently of the colors. This provides a much more uniform, pure, and bright white color than the traditional method of combining all RGB signals.
To drive the LEDs safely, a new constant-current driver is included for each set, for high reliability. You will also need a standard RGB or RGBW controller. Controllers can usually be powered by any standard 12V source. We recommend connecting to the parking light signal, so this module lights up when the parking lights or headlights are on, or to the factory power input signal.
There is a standard RGBW input plug (5-pin) to connect to your RGBW controller. This connector is plug-and-play with Diode Dynamics controllers. We strongly recommend the use of Diode Dynamics controllers with this product, for ease-of-use. However, you can connect any standard RGB or RGBW controller by cutting the pins off the connector end, and connecting them to your controller, in the required color configuration, as dictated by the controller you use. This does not void the warranty.
Professional installation is strongly recommended, as the factory headlights must be opened in order to replace the LED panels.
All Diode Dynamics products are backed by a 3-year replacement warranty.
2015+ Dodge Charger RGBW LED Boards
If you have any questions, please don't hesitate to post, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
· Supporting Vendor
I bought these but seem to be having a hard time finding someone who will install them for me. Any partnering installers in Long Island, NY? What is the approximate install time?
We have a dealer locator tool here on our site: http://www.diodedynamics.com/store/index.php/find-dealers/
Here's a professional installer in Long Island:
Robert:
Xotic Reflectionz
1 Leroy Ave.
Brentwood, NY 11717
Phone Number: (631) 922-0182
Type: Installation
E-mail: [email protected]
I suggest giving him a call to see if you can schedule an installation
Thanks!
Nick C.
How long will these last?
Sent from my SM-N910P using Tapatalk
1 - 20 of 35 Posts
